Thread: Samsung errors
    JWK's Avatar
    JWK Guest
    Samsung errors
    I have a Samsung Air Conditioner model AQV12MSAN.
    Recently I encounter the following problem:
    When opperates in Heat Mode and adjusted temperature less than 22C - the Air Conditioner turns off itself and displays E2-37 or E4-16 at the display panel (First E2 - then 37, First E4 then 16).
    Could you tell me please what these errors means.
    Thank you in advance for your help.
    Apr 2006
    stafford
    42
    974
    Re: Samsung errors
    E237 = Coil temperature sensor Error
    E416 = Discharge over temperature
    happy hunting hope this helps
    Paul
    "KEEP IT COOL"
    aquila's Avatar
    aquila Guest
    Samsung error codes of AQV12EWAN
    Hi!
    I have a Samsung Air Conditioner model AQV12EWAN (2009 Model).
    Could somebody help me with a table containing the error codes and descriptions?
    Thnx!
