Thread: Split 3 way valve
12-05-2009, 12:03 AM #1
Split 3 way valve
Regarding ductless mini-split systems
I have a doubt about the 3 way valve on the outdoor unit gas side
Are them all only 2 position (closed/open) with a schrader valve on the service port ?
Or are some of them 3 position, like in the compressor valves in refrigeration system ?
Moises
12-05-2009, 11:40 PM #2
Re: Split 3 way valve
They are normally only 2 position valves, some have a Schraeder, some do not.
They are not back-seating valves only open/close.
Back-seat Valve ---
13-05-2009, 05:01 AM #3
Are you talking about the reversing valve, if you are they are oneway or the other, no in-btween.
magoo
14-05-2009, 02:08 PM #4
Thank you Brian and Magoo
Brian answered my question
Now I know that the 3 way air conditioning valve
has only 2 positions and the 3 way refrigeration system valve has 3 positions
Most service manuals does not make it clear
This is a great forum with great techs
Moises
14-05-2009, 10:47 PM #5
Forgot to add that with the 2 position valve when you close the valve the Schraeder is open to the pipework side of the valve.
This is so that you can pressure test/evacuate etc the pipework without the condensing unit.Brian - Newton Abbot, Devon, UK
29-05-2009, 11:09 PM #6
Thank you Brian
But now there is a doubt left:
When I close the valve the Schraeder is open to the pipework side, as you said.
When I open the valve, does the pipework side gets closed or is the Schraeder valve that closes the pipework side by itself ?
I am asking this because you told some valves do not
have a Schraeder on them.
MoisesLast edited by Acrisoft; 29-05-2009 at 11:15 PM.
29-05-2009, 11:58 PM #7
No, when you open those valve all you have done is open the port between the two pipes.
Motorized Ball valve versus Globe valve for modulating application
By Sridhar1312 in forum IndustrialReplies: 2Last Post: 06-02-2009, 07:35 PM -
R22 Flooded System - Trawler
By chiefbecker in forum System OptimizationReplies: 18Last Post: 07-02-2008, 11:11 PM -
Service Procedures For TK Scroll
By absolute-zero in forum TransportReplies: 0Last Post: 03-02-2008, 07:42 PM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
TEV with MOP: how to keep valve body temp above bulb temp?
By DaBit in forum FundamentalsReplies: 5Last Post: 16-10-2002, 12:38 AM
