29-09-2008, 11:42 PM #1
Help! Liebherr freezer too cold .....
Hi, I'm new to the site, so please go easy!
I'm looking at a 6yo Liebherr GSS2763 freezer, very clean and no faults to date.
Last w/e freezer shot up to maximum display (-32c) and shows no sign of control. Have shut it down and re-started according to the book, but so far it's at -21c and dropping (should stop at -18c).
Could this be a sensor failure? I read that Liebherr had some problems with fridges some years back, but can't see any similar issues with freezer. The handbook is about as useful as a chocolate fireguard, as it's only concerned with failure to freeze!
Any help/thoughts welcome
Cheers from sylly Suffolk!
29-09-2008, 11:55 PM #2
Re: Help! Liebherr freezer too cold .....
Have you checked the actual temperature within the freezer and how does it compare with the control unit display ?
edit:
Unfortunately not free but if you want a service manual you can buy one from here...
http://www.manuals-in-pdf.com/GSS276...cturers_id=476Last edited by Brian_UK; 29-09-2008 at 11:57 PM.
30-09-2008, 12:04 AM #3
Hi Brian - haven't checked the actual temperature yet, but food seemed well below -18C .... I couldn't bite into a choc-ice!
Seriously, by obsevation I believe the freezer is running too cold .... but since this model only has LEDs for -18, -21, -25 and -32 it's hard to tell how low it's manageing to drop the internal temp.
30-09-2008, 12:08 AM #4
Sorry, don't know the model concerned so was only guessing.
Sound like a stuck thermostat control or relay somewhere keeping the compressor running.
Time to get the multimeter out methinks.Brian - Newton Abbot, Devon, UK
fridge warm freezer cold?
By babsnsarah in forum DomesticReplies: 25Last Post: 30-04-2011, 04:24 PM -
Hotpoint ffa71 freezer wont go cold
By efergie in forum DomesticReplies: 7Last Post: 03-11-2008, 01:44 PM -
Hoover Optima - Freezer warm, fridge cold
By aberchick in forum DomesticReplies: 3Last Post: 08-05-2008, 09:45 PM -
Beko Fridge Freezer Bubbles & Does Not Get Cold!!!!
By scoobey in forum DomesticReplies: 11Last Post: 16-03-2008, 07:12 PM -
Freezer not cold enough, Fridge too cold
By barrance in forum CommercialReplies: 4Last Post: 06-12-2001, 06:11 PM
