Results 1 to 11 of 11
    Nov 2007
    South Africa
    64
    5
    Design heat pump for a pool
    Hi All
    I hope somebody can help me in the design of a heat pump for my pool? I have got a 18000 Btu heat pump air conditioner. I would need some advice in connectin a heat exchanger onto the unit. I wasd thinking in using a PE4 unit from Onda heat transfer solutions. All help will be highly appreciated.
    Mar 2005
    Lanzarote
    41
    372
    Re: Design heat pump for a pool
    How big is the pool?
    Personally I wouldnīt bother trying to make one. Just buy a proper one and be done with it.
    If you really want to do it then, that PE4 is and evaporator and you need a condenser. Also it doesnīt say on there what thatīs made from. If you can, you want a titanium condenser. The pool chemicals will eat through copper. Youīll also need some sort of a safety, like a flow switch or something, so if your pool pump fails the heatpump stops. You could just use the HP switch in the air-con unit you have (assuming it has one), but itīs better to stop it before the pressures get high enough to trip it.
    nevgee's Avatar
    nevgee is offline Veteran Poster I am starting to push the Mods: of RE
    May 2006
    Yorkshire
    72
    417
    copper is ok with swim pool water so long as the ph is kept to 7.4 +/- 2 and the free chlorine and combined chlorines are kept in balance.
    Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
    Nov 2007
    South Africa
    64
    5
    It is a small pool of +-12000 Litres andit is also a salt water pool. To buy a unit in South Africa ia very expensive. Also, why would I need a condenser I already have the condenser with compressor from the Ac unit? As far s I know , I wwill substitute the inside blower (evaporator) with a heat exchanger.
    Split Croatia
    57
    6,151
    36
    Swimming pool heat exchangers should be from materials and cleaning ability like this one. Also, you need a flow switch to stop the compressor/heat-pump when there is no enough flow (diferential pressure).
    nevgee's Avatar
    May 2006
    Yorkshire
    72
    417
    Forgive me for seeming to be stupid here, but I think you'll need a condenser for the pool water heat exchanger ... not an evaporator. How else will you be able to reject heat into the pool water?
    The evaporator will be at the air source.
    Please retract my previous comment about using copper, which is ok with fresh water but not if the pool water is salt water. You'll need a cupro nickel heat exchanger or simillar if you're to limit corrosion problems.
    nevgee's Avatar
    May 2006
    Yorkshire
    72
    417
    you can get details of co axial heat exchangers at these sites
    http://www.wieland.de/internet/index.jsp
    http://www.coaxial-coils.com/Cuproni...-exchanger.htm
    Mar 2005
    Lanzarote
    41
    372
    A company that used to be here were selling heat pumps made in South Africa for 1000€. I see if I can find out what make they were, iīm sure you would pay a lot less than that, as you are in South Africa. I donīt know if they were any good though.
    malaysia
    159
    Quote Originally Posted by rolandh View Post
    Hi All
    as far as i remember, the heat loads come in 2 parts.
    1. evaporation losses thru the surface which includes wind load;
    2. circulation rate of the pool.
    the circulation rate is practically governed by the desired turbidity level of the pool. there is 4 hrs, 8 hrs and so on.
    next, you have to decide the temperature you want; that very much form the heat pump capacity in a nutshell.
    i hope it helps you.
    "it is very satisfying when you find crowds dip into the hot pool you designed."
    Hendry
    "What uncertainty means to you, and you only?"
    Sep 2010
    South Africa
    7
    why not just get your self a custom designed heat pump for your pool? it save you alot of time and effort
    Mar 2009
    KZN, South Africa
    64
    2,212
    Quote Originally Posted by Fire Fly View Post
    Welcome, FireFly.
    Are you a heat-pump designer operating in SA?
  1. frostles heat pump
  2. swimming pool heat pump
    By Andy AC in forum The Trail of Tears
    Last Post: 26-08-2007, 04:02 PM
  3. Heatstar swimming pool heat pump
    By Latte in forum Trouble Shooting
    Last Post: 28-06-2007, 06:15 PM
  4. pool heat pump
    By coolflow in forum Heat Pumps
    Last Post: 12-05-2006, 07:19 AM
