Thread: Manifold Leak ??
25-09-2008, 08:50 AM #1
Manifold Leak ??
I was doing some vacuum testing today and was getting real confused until I found that my vacuum manifold was leaking.
It is a Yellow Jacket Super-evac, the one with 2 ball valves and a compound gauge on top.
I finally found the leak by using pressure/N2 and some Snoop on the fittings. It has a tiny leak on the upper threaded fitting.
Anyone know what the red thread sealer is that Yellow Jacket uses? I doubt that it is regular Loctite?
I hate to take it apart unless I have to, will probably have to use heat and it could ruin the ball valve seats.
Any ideas on how to possibly seal it?
25-09-2008, 10:47 PM #2
Re: Manifold Leak ??
I've used 'tru-blue' by Rectorseal on my manifold to seal the new gauges, i guess it would work ok on a vacuum manfold too.
Jon
25-09-2008, 11:21 PM #3
Leak Lok or any good refrigerant proof seal will do it
26-09-2008, 05:43 PM #4
Teflon will do the job very good.
Also cheaper.
Leak detectors
By Temprite in forum Tools and CalculatorsReplies: 54Last Post: 18-08-2010, 04:15 PM -
Leak Testing Daikin K Series VRV
By jedi in forum Trouble ShootingReplies: 8Last Post: 21-08-2008, 07:16 PM -
Evasive gas leak
By Feeze in forum Technical DiscussionsReplies: 24Last Post: 18-08-2008, 07:22 AM -
Gas Leak!
By Chunk in forum Chit Chat & Service StoriesReplies: 18Last Post: 31-03-2008, 06:48 PM -
Help!!! Shell and Tube Evap Leak
By tommy Gun in forum Trouble ShootingReplies: 7Last Post: 22-07-2007, 12:45 PM
