    Sep 2008
    65
    8
    Manifold Leak ??
    I was doing some vacuum testing today and was getting real confused until I found that my vacuum manifold was leaking.
    It is a Yellow Jacket Super-evac, the one with 2 ball valves and a compound gauge on top.
    I finally found the leak by using pressure/N2 and some Snoop on the fittings. It has a tiny leak on the upper threaded fitting.
    Anyone know what the red thread sealer is that Yellow Jacket uses? I doubt that it is regular Loctite?
    I hate to take it apart unless I have to, will probably have to use heat and it could ruin the ball valve seats.
    Any ideas on how to possibly seal it?
    3,853
    Re: Manifold Leak ??
    I've used 'tru-blue' by Rectorseal on my manifold to seal the new gauges, i guess it would work ok on a vacuum manfold too.
    Jon
    11,025
    Leak Lok or any good refrigerant proof seal will do it
    Sep 2003
    ISRAEL
    72
    4,248
    Teflon will do the job very good.
    Also cheaper.
  1. Leak detectors
    By Temprite in forum Tools and Calculators
    Last Post: 18-08-2010, 04:15 PM
  2. Leak Testing Daikin K Series VRV
    By jedi in forum Trouble Shooting
    Last Post: 21-08-2008, 07:16 PM
  3. Evasive gas leak
    By Feeze in forum Technical Discussions
    Last Post: 18-08-2008, 07:22 AM
  4. Gas Leak!
    By Chunk in forum Chit Chat & Service Stories
    Last Post: 31-03-2008, 06:48 PM
  5. Help!!! Shell and Tube Evap Leak
    By tommy Gun in forum Trouble Shooting
    Last Post: 22-07-2007, 12:45 PM
