Thread: split v/s vrv
23-09-2008, 10:15 AM #1
split v/s vrv
hi every one,,,,,
1. can you plesae tell me the difference between a split unit of ac and a vrv system...........
2. which one is beneficial to a firm (11 stories) , using a vrv system and chiller plant.
regards
manender (m@ddy)
manenderdhariwal@gmail.com
23-09-2008, 04:57 PM #2
Re: split v/s vrv
11 Stores, that's going to be a lot of splits...
VRV/VRF or chilled water would be the only feasible options. Which one would be most beneficial in your case is impossible to say without seeing the job.
Get a couple of quotes in from local companies and see what they suggest.
Australian split installers, some info needed
By paul_h in forum Air ConditioningReplies: 10Last Post: 20-05-2008, 03:40 PM -
Do you beleive in data of split units?
By jirhol in forum FundamentalsReplies: 4Last Post: 29-03-2008, 11:17 PM -
High overcurrent on 3.5kW heatpump split
By Makeit go Right in forum Air ConditioningReplies: 12Last Post: 08-03-2007, 12:27 AM -
Cooling condenser of split with condensate from evaporator
By smileypete in forum Air ConditioningReplies: 11Last Post: 10-07-2005, 08:21 AM -
LG ducted split
By Abe in forum Air ConditioningReplies: 20Last Post: 08-06-2005, 07:19 PM
