Untitled
Carrier
2013
Results 1 to 10 of 10
    Feb 2007
    47
    165
    7
    ThermalTake Xpressar
    Anyone tried this yet, or have opinions?
    http://www.dvhardware.net/article30006.html
    http://www.xpressar.com/product/rsc1...-features.html
    I'm not looking for super low temp stuff, just a quiet, reliable cooling solution for video processing machines.
    Steve
    Oct 2008
    Bristol
    48
    Re: ThermalTake Xpressar
    R134a won't deal with the heat loads off todays GPU all that well nor a CPU.
    I just took delivery of 4 of these compressers, thankfully i have some freinds in high places. A mate wants to play with them and see what he can make!
    There 12v and draw 50w
    Apr 2006
    30
    1,416
    9
    Quote Originally Posted by pjalchemist View Post
    R 134a has just dandy capacity, with out temp the statement you made is meaningless to say the least, all so depends on compressor and condensor!
    It's thermaltake, that says it all! Ie garbage!
    May 2008
    Brazil
    1
    Exclamation Re: ThermalTake Xpressar
    Cool....
    Where can I get one of these ?
    Apr 2006
    30
    1,416
    9
    Just buy the compressor and make your own, the idiots have the compressor insulated! good way to kill it fast!
    Split Croatia
    5,631
    1
    14
    Quote Originally Posted by The MG Pony View Post
    If it is cooled with refrigerant then there is no such a danger. Also, if it is not insulated and not cooled by refrigerant it will then additionally heated PC housing and component's in it.
    Apr 2006
    30
    1,416
    9
    It is a rotery, discharge is the shell and suction gas goes directly to the compression chamber!
    So it will quite adaquetly heat the PC shell! This is not an issue as case fans will deal with this heat aptly! it is only one spot we need cool!
    Oct 2008
    Bristol
    48
    Gonna try and play with one this week out the 4 i have here now!
    Oct 2008
    Tonawanda, New York
    1
    pjalchemist,
    Where might one order them?
    Oct 2008
    Bristol
    48
    I have a freind that personly works at Thermaltake whom sent me them.
    There made in china
