Results 1 to 37 of 37
Thread: Backup Maintenance
Threaded View
13-04-2002, 05:51 AM #24I like that, Gary. But speed is regrettably a high priority when you bill service work. The most likely negotiating point with a customer is how long the repair took. Right after obvious callbacks.
I have known contractors who will pad the bill a little, knowing who the negotiators are, then shave it down for them, and everyone is happy.
Not that I would recommend such a practice, mind you.
In any case, this is your cross to bear. The service tech's cross is callbacks, and quality of work should always be his main focus.
Everyone tries to avoid what gets him in trouble.
If you tell the service tech he takes too long, he will cut corners, and the quality of his work will suffer.
If you tell him about his callbacks, he will try to improve the quality of his work.
Which would you have him do?Last edited by Gary; 13-04-2002 at 06:10 AM.
Mitsubishi M-Net maintenance tool for sale?
By sigorst in forum Air ConditioningReplies: 6Last Post: 14-12-2009, 08:40 PM -
Air conditioning maintenance procedure
By Andy T in forum Air ConditioningReplies: 12Last Post: 27-05-2006, 06:57 PM -
Mitsubishi M-Net Maintenance tool
By sigorst in forum Air ConditioningReplies: 3Last Post: 07-03-2006, 05:27 PM -
Maintenance contract
By botrous in forum Legal-Business-MarketingReplies: 8Last Post: 30-04-2005, 10:29 PM -
maintenance
By Servicefrigo in forum Technical DiscussionsReplies: 10Last Post: 27-01-2005, 04:02 PM
