    Sep 2008
    usa
    27
    Problem with plugged condenser
    Insalled new 3 phase scroll compressor, R22 system.
    the old one was rattling and making noise and not pumping.
    now the new one runs fine for a minute and starts pumping down and all the sudden the high pressure internal safety valve on the compessor pops. the high side guage is only reading 180 psi at the discharge of the condenser. so this tells me the condenser must be plugged.
    i backflushed the condenser with nitrogen today and nothing came out and seemed free from any kind of plug or chunks of anything.
    also installed a shrader valve near the discharge of the compressor to check psi there but it sure seems like the condenser is plugged up. i will try running it again later and check the PSI just after the compressor on the discharge side..
    any ideas?? i have a bad feeling its going to do the same thing even after i flushed the lines with nitrogen because they sounded clean and nothing came out.????????????????
    rd_shetty2003's Avatar
    rd_shetty2003 Guest
    Re: Problem with plugged condenser
    hi friend
    did u checked compressor rotetion? i feel compressor running in wrong rotetion. just change the phase and run the compressor .hope it will work well
    Quote Originally Posted by kurt s View Post
    Sep 2008
    usa
    27
    yes tried that wirring is ok, pumping well as stated but internal pressure safety still pops. i will find out more very soon.
    thank you though
    3,856
    I've had a vibration eliminator collapse internaly and do something similar.
    rd_shetty2003 Guest
    hi kurt s
    is it split a/c unit? u didnt mention brand of the unit. some unit has filters in indoor distibuter.if its 180 psig condersor outlet pressure then u r outdoor units is ok.plz check u r indoor unit
    regards
    dinesh shetty
    Feb 2007
    newcastle but now carlisle
    195
    is this the comp you had problems with running the wrong way ?
    Vishwaprasanna's Avatar
    Vishwaprasanna Guest
    Have u compair old and new compressor's specification?
    May 2008
    66
    802
    if the outdoor unit comes whit a capillary,there must be a small filter and valve build to it. try to change the complete capillary set whit filter and reverse valve. it might work.
    the filter and valve is a thicker tube at the end or beginning of the capillary and functions like a injector.
    hope you now what i mean,pitty i don't have pictures at hand.
    Ice
  1. Superheat and Subcooling
  2. A strange problem
    By MuhengineeR in forum Air Conditioning
    Last Post: 27-10-2010, 05:21 PM
  3. Air Cooled Condenser Leakage Problem with R-404A
    By RADHAKRISHNARAO in forum Technical Discussions
    Last Post: 30-07-2008, 12:21 PM
  4. Furance problem
    By ALONEI in forum Trouble Shooting
    Last Post: 14-05-2008, 11:32 AM
  5. Condenser Length Problem
    By tanveerkuet in forum Technical Speculations
    Last Post: 01-02-2008, 12:05 PM
