Thread: Pipe Wall Thickness
18-09-2008, 02:57 AM #1
Pipe Wall Thickness
What kind of wall thickness is required for copper tubing in evaporator running at ultra low temp i.e. -90F SST.
Any ideas!!
18-09-2008, 11:33 PM #2
Re: Pipe Wall Thickness
18 gauge copper will cover it http://www.spiralmfg.com/downloads/p...properties.pdf
60% of the time it works everytime.
18-09-2008, 11:54 PM #3
The pressure that you need to refer to is the static pressure at the ambient temperature when the system is not running.
19-09-2008, 12:10 AM #4
As Brian indicated, the wall thickness is based on the highest observed pressure. It does not matter if it is running or not. Which condition has the highest pressure?
Obviously, for this case cited the highest pressure would be during a shut down condition.If all else fails, ask for help.
19-09-2008, 12:13 AM #5
I suppose you could also look at the crushing conditions when the pipe is surrounded by ice ???
19-09-2008, 01:16 AM #6
19-09-2008, 10:55 PM #7
To be honest I wouldn't think that there would be a major icing problem.
To achieve those temperatures would normally require a(n) (en)closed space so there would be a limited amount of moisture to be turned into ice.Brian - Newton Abbot, Devon, UK
Burst Pipe caused by Abrasion. (aka Only on a Friday)
By Grizzly in forum Chit Chat & Service StoriesReplies: 11Last Post: 19-09-2008, 06:59 PM -
Mitsubishi PUHZ-RP200YHA Pipe Sizes
By gwilliamson in forum Air ConditioningReplies: 11Last Post: 14-05-2008, 09:43 PM -
pipe insulation thickness
By bangoman in forum Air ConditioningReplies: 3Last Post: 24-04-2008, 08:43 PM -
Split type wall mounting Air Conditioning system
By stevews in forum Air ConditioningReplies: 23Last Post: 11-07-2005, 09:55 AM -
Pipe sizes
By benncool in forum Chit Chat & Service StoriesReplies: 10Last Post: 08-07-2003, 10:58 PM
