    Apr 2005
    edinburgh
    29
    Red face R-404a running pressures
    hi can anyone tell me the approx running pressures for R-404a on an upright freezer. its been a while since i last used this gas. cheers dougie.
    Jan 2007
    scotland
    40
    159
    12
    Re: R-404a running pressures
    hi dougie,
    i tend to run suction at around 0.7/1.4bar and as long as the hp is below 15bar it should be okay but it really depends on the case.
    zosoguy's Avatar
    zosoguy Guest
    it depands on the evaporation temperature...
    if evaporation temperature is -40 C then suction pressure is around 1 - 3 psig and condensing pressure around 200 psig.
    if evaporation temperature is -25 c then sp might be approx. 10-12 psig and condensing presssure might be up to 220-240 psig.
  1. Problems with compressor running too cold
    By abrando1 in forum Trouble Shooting
    Last Post: 12-05-2009, 10:08 PM
  2. running pressures
    By sean1 in forum Fundamentals
    Last Post: 03-04-2008, 01:38 PM
  3. R 404a
    By Samarjit Sen in forum Refrigerants
    Last Post: 07-08-2007, 06:35 PM
  4. Walkin cooler running to warm need help
    By The Butcher in forum Trouble Shooting
    Last Post: 03-08-2007, 09:19 PM
  5. Running Pressures!
    By G_Young in forum Air Conditioning
    Last Post: 16-11-2006, 11:00 AM
