Results 1 to 10 of 10
    Dec 2003
    Essex
    52
    37
    Surfrigo Capiliarry
    I have just come across a surfrigo unit running on R22 with the capially line running inside the suction line. Now i need to change the capillary tube, i assume it runs inside to suction as a heat exchanger but do i have to put the new one inside again or would i get away with running it along the outside.
    Thanks for any help
    Mar 2002
    San Francisco Bay Area
    180
    23
    I am not familiar with "surfrigo". I have had to replace an R-12 cap which ran inside the suction line. Have done it with an exterior one, but stripped what insulation remained on the suction line and taped the new cap to the suction tubing before re-insulating.
    Oct 2003
    5,630
    34
    Grabber, will work fine the way you will do it.
    The impact of the heat exchanger effect is rather small due to the very smaal surafce area of a capillary.
    Surfrigo is from Italy.
    rbartlett's Avatar
    rbartlett Guest
    get a cap tube drier kit from srw £4.50 plus p&p
    cheers
    richard
    May 2002
    The Netherlands
    48
    274
    23
    You might find that your captube is too long when you run it outside. Not subcooling it increases the 2-phase part of the captube, increasing it's resistance.
    Try it and you know it...
    Sep 2003
    ISRAEL
    72
    4,248
    hi grabber,
    first, you can put the new one as it was, inside. more work.
    you can wrap it arround the suction line.
    by letting it hang along the suction line, movments will cause waer and evntually a hole.
    soldering it to the suction line is another possibility.
    chemi
    Jun 2002
    628
    23
    sufrigo capillary
    hi grabber
    Was the old capillary blocked,waxed,fractured ?.Can the capillary possibly be cleaned?.If not measure the line diameter and length and fit a cap-kit(hrp) . Parts are available for sufrigos and could source a direct replacement.I have fitted capillarys external to suction line and the losses are negligible.
    regards mark
    Dec 2003
    Essex
    52
    37
    Thank-you to all who replied. I am trying to make good an old fridge for sombody & it had a crushed suction pipe. Like the idiot i am i cut through it to cut the damaged section out without realising the capillary was inside. No i am thinking it's easier to put a new one in around the suction than trying to flare to pipe with the capillary inside it
    Sep 2003
    ISRAEL
    72
    4,248
    dont flare it!!
    solder it.
    chemi
    Dec 2003
    Essex
    52
    37
    Hi Guys,
    I would like to solder it but as i have been a prat and cut through the suction line i can not see how i can get in there to flare one side without damaging the capillary that runs inside it.
    Does anyone know of a surfrigo stockist in the uk that might know the size/diameter of the cap tube to save me having to go back & take a piece off. The unit is an STRB5-12 if hat helps anyone.
  1. Surfrigo parts
    By bldref in forum Commercial
    Last Post: 10-08-2005, 06:44 PM
