    Sep 2008
    Philippines Islands
    59
    29
    Definition for cooler selection
    Hallo,
    please, I'd like to understand better a definition I have found in a Bohn technical sheet.
    I find the definition of "room temperature" as air reference temperature.
    Is it the air inlet temperature in the coil or is it something different ?
    Aug 2005
    5,302
    Re: Definition for cooler selection
    You can assume the room temperature and the temperature of the air entering the coil to be the same (unless cold air short circuits from another coil).
    Dec 2001
    137
    23
    Usually the room temperature and the air temperature coil are the same. This is not always the same as the air entering the coil could be from a different area or have an element of another air stream such as a fresh air supply.
    Most manufacturers of room air con will use the room temperature as the referance as the end user will understand the refeance
    Brit
  1. Grasso compressor selection chart
    By Rajkumar in forum Industrial Compressors
    Last Post: 01-11-2009, 10:59 PM
  2. TX Valve Selection: PHT or TE
    By JERRYCOOL in forum Industrial
    Last Post: 05-08-2008, 02:10 AM
  3. Replies: 3
    Last Post: 19-02-2007, 04:22 PM
  4. Evaporator Selection
    By chooipeng in forum NH3
    Last Post: 26-09-2006, 08:11 AM
  5. selection of centrifugal fan
    By watana in forum Air Conditioning
    Last Post: 14-09-2003, 04:02 AM
