Thread: Heat Reclamation
12-09-2008, 09:53 PM #1
Heat Reclamation
I have a refrigerator that is 3300 sq ft. I have designed hydronic system for frost protection system that requires 5 btu/sq ft. There is 3/4" PEX tubing used at 24" OC
I have been asked how to pipe and collect the heat off the compressor and use it for the frost protection.
I assumed there would be some sort of heat reclamation tank that could be used. I am concerned that the frost protection system would not use enough heat off the compressor. I am trying to find out more information on the compressor. Freezer is going to be at -4F.
Has anyone seen a product used for this? If so what is the name of the product
Has anyoned designed something like this? If so can you point me in the right direction
13-09-2008, 07:08 PM #2
Re: Heat Reclamation
07-11-2008, 01:16 PM #3
Is it not cost effective to use a hot gas defrost?
07-11-2008, 02:23 PM #4
08-11-2008, 09:09 AM #5
ahh... I understand now.... thank you... sorry
Capacity control
By sparrow in forum TrainingReplies: 44Last Post: 18-01-2010, 07:49 PM -
Some information on the aplication of suction gas/liquid line heat exchangers
By SteinarN in forum FundamentalsReplies: 5Last Post: 14-09-2009, 07:33 AM -
System sizing for heat and manual J
By Larry2 in forum Heat PumpsReplies: 5Last Post: 25-06-2008, 10:58 AM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM -
heat exchanger for small chiller
By star882 in forum FundamentalsReplies: 4Last Post: 30-01-2007, 12:06 PM
