Results 1 to 10 of 10
Thread: Testing air-duct
11-09-2008, 05:15 AM #1
Testing air-duct
Please tell me, how test air-duct ? What colour-smoke are used which it no inflluence on an environment ?
11-09-2008, 11:51 PM #2
Re: Testing air-duct
What sort of test are you trying to do?
Leakage test
Airflow testBrian - Newton Abbot, Devon, UK
17-09-2008, 06:38 PM #3
in 1880's the indians use white smoke,now we have technologie and digital testers .
Ice
ps;just kidding.
17-09-2008, 11:33 PM #4
Seems to be a one question wonder sadly....
18-09-2008, 06:22 AM #5
Hi Long Nguyen
Special smoke candles or a smoke generator were and are still sometimes used to check airflow patterns , leakage in rooms or ducting.
You can easily source them from USA etc by doing Google search. Problem is they cannot be sent on airfreight to HCM, HK etc from overseas now ( safety and security laws).
I heard of Dry Ice being used to generate such 'smoke effect' as alternative - but have not seen such test personally.
Hope it helps.
regards
T-PRemember what Augustus once said:
"festina lente" - make haste, slowly!
04-10-2008, 10:45 PM #6
you can make your smoke machine yourself if you connot obtain any.
All you need is a pump, a heater, nozzle and a blower.
Use a glycerine based solution , pumpe it to the nozzel in the direction of the heating plate , the blower will help the smoke to diffuse in the duct system.
A dense white smoke will be generated , if you can you can color the solution with any volatile colorant and you will get it colored.
Respects and regardsEngineering, sciences, math, physics and my brain will generate "not responding " soon
04-10-2008, 10:48 PM #7
Hi Botrous, good to read you again.
Hope all is well with you and yours.Brian - Newton Abbot, Devon, UK
04-10-2008, 11:40 PM #8
05-10-2008, 12:27 AM #9
We are fine thank you.
Presently sitting here listening to the rain pounding on the windowsBrian - Newton Abbot, Devon, UK
05-10-2008, 12:40 AM #10
Glad to hear that you are ok , enjoy the season
Duct Size Calculations
By hamidpia in forum Tools and CalculatorsReplies: 17Last Post: 21-06-2010, 01:56 PM -
Duct Sizing!
By C_Henderson in forum Air ConditioningReplies: 3Last Post: 02-03-2008, 08:14 PM -
duct designe
By zarohliburd in forum Air ConditioningReplies: 4Last Post: 19-08-2007, 08:11 PM -
OFN Pressure testing hoses.
By Teknicool in forum Trouble ShootingReplies: 7Last Post: 08-07-2007, 11:41 AM
