    ayo's Avatar
    ayo Guest
    Question What is compressor size for evaporator KM140-4?
    Hi members,
    I have a cold room unit consisting of two evaporators with three fans each(of 3 phase): make of evaporator is SEARLE KM140-4; serial no. 866582:
    • what type and size of the compressor is most compatible for this unit?
    • what is the best refrigerant for this unit?
    thanks!
    11,025
    Re: What is compressor size for evaporator KM140-4?
    The most compatible condensing unit would be the one that was first fitted to the cold room and connected to the two evaporators.
    What refrigerant is specified for the existing equipment?
    Apr 2008
    philippines
    95
    just write the specs in your compressor..
    compressor LRA, Supplied voltage.. and bring it to the refrigeration equiptment..
    the refrigerant type to be used is also written in the nameplate of the compressor..
    With great power Comes Great Responsibility
