Results 1 to 8 of 8
Thread: Glycol pipes.
    balnauld's Avatar
    balnauld Guest
    Glycol pipes.
    HI, I have leaking glycol pipes under the cold store floor digging up the floor is not an option,
    any other suggestions.
    Feb 2007
    2,473
    45
    Re: Glycol pipes.
    Biig can of Radweld??
    11,025
    Re: Glycol pipes.
    A little explanation of what the pipes are serving might help things along a bit.
    My first thought with the limited info would be to run the pipes around the outside of the cold store.
    Somerset
    69
    4,706
    Re: Glycol pipes.
    Quote Originally Posted by balnauld View Post
    Normally the glycol is used to form a thermal barrier between the Cold Chamber/s and the Ground they are sat on! ( I presume this is the dilemma?)
    Prevents Meters of Perma frost in the ground below.
    Sorry balnauld! Personally I don't know of a way around digging them up to repair them.
    May 2008
    New York
    93
    Re: Glycol pipes.
    I agree. You will not stop the pipes from leaking without digging up the floor. If you just valve off the leaking circuits you will be digging it up later anyway due to the heaving floor from the perma frost that Grizzly mentioned. Normally they don't just start leaking if the proper material was used. Has something changed or did something happen? I had a customer that had the glycol pump fail and decided to put it off for budget reasons. The pipes froze and burst. Not good!
    May 2008
    hungerford
    8
    Re: Glycol pipes.
    not much help now but i would always considor electrical heater mat from day one much more of a safe option
    May 2008
    New York
    93
    Re: Glycol pipes.
    That is am interesting statement. Why do you say it is safer? Why is Glycol underfloor heat dangerous?
    May 2008
    hungerford
    8
    Re: Glycol pipes.
    not to say that glycol is dangerous just that with an electrical system the heater is made of a stainless steel wire therfore not much to go wrong ie damage leeks etc
  1. glycol charts
    By Feargal Loy in forum Technical Speculations
    Last Post: 28-03-2010, 03:19 AM
  2. glycol cooling system for soft dring
    By faryuki in forum NH3
    Last Post: 21-04-2007, 03:44 PM
  3. Milk getting into glycol on chill press
    By balerjoe in forum Trouble Shooting
    Last Post: 06-09-2005, 09:41 PM
  4. Glycol water valves
    By eng_ab in forum Industrial
    Last Post: 03-06-2005, 09:15 PM
  5. which glycol to use ?
    By dchatta in forum Refrigerants
    Last Post: 12-07-2004, 09:26 AM
