Results 1 to 8 of 8
Thread: CO2 Or N20?
08-09-2008, 11:46 AM #1
CO2 Or N20?
Just a quick one. I have looked at the properties of these two gasses and cant find why we don't use N20 (nitrous oxide) instead of CO2?
08-09-2008, 12:33 PM #2
Re: CO2 Or N20?
Because everyone would steal it?
09-09-2008, 12:22 AM #3
09-09-2008, 07:59 AM #4
Re: CO2 Or N20?
Can you imagine how fast your van would go.zooooooooooom
09-09-2008, 08:48 AM #5
Re: CO2 Or N20?
Here's a quote from the United States EPA
Nitrous oxide (N2O) is a clear, colorless gas, with a slightly sweet odor. Due to its long atmospheric lifetime (approximately 120 years) and heat trapping effects —about 310 times more powerful than carbon dioxide on a per molecule basis — N2O is an important greenhouse gas....and she said "give it to me you big fridgie"
16-09-2008, 09:24 PM #6
Re: CO2 Or N20?
750Valve. This doesn't look right.
R22 has a GWP of someting like 1600 and R410A (a current replacement for R22) is even higher. So, this can't be the reason.
16-09-2008, 09:26 PM #7
Re: CO2 Or N20?
Sorry, I just noticed that it hangs about for 120 years; much more than the others I mentioned.
16-09-2008, 10:47 PM #8
Re: CO2 Or N20?
N20 is a good refrigerant. The triple point is at -90°C, over 36° lower then CO2, and the critical point is 6°C higher than CO2.
It has similar pressures, so it can be a drop in substitute for CO2 in very low temperature or transcritical criogenics.
The only drawback is a GWP of 240.
