06-09-2008, 02:25 PM #1
E2V EEV from Carel in hotgas Defrost
Does someone know if the E2V fully opens or fully closes when starting a hotgas defrost?
Can't find it in their manuals.
If it closes, then it acts as a SV.
If it opens, then it acts as a NRV and we don't have to install a NRV.
06-09-2008, 04:38 PM #2
Re: E2V EEV from Carel in hotgas Defrost
Hi Peter.
I would think that it would be the same principle as the danfoss AKV, you need an nrv because the eev will be open 100% to get the flow of hotgas back into the liquid line.If it ain't broke, it doesn't have enough features yet.
Damo
06-09-2008, 05:42 PM #3
If the AKV is fully open, why then you need an NRV?
Is a schematic of this somewhere available?It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
06-09-2008, 06:51 PM #4
Yes my cabinets using AKV`s all have nrv`s but they can be set to have the valves open or shut on defrost(people like fiddling with settings so they are all over the place).
The carel version looks like a more complicated version of the Danfoss,and like you i have just read through all of their literature,and cannot find anything usefull,or hot gas schematics.
If carel have any sense,then they would have parameters to let people set the valve to do what they want.
I have been of no help againso i shall slink off.If it ain't broke, it doesn't have enough features yet.
Damo
Toshiba RAV SM/SP1400 defrost problem
By SteinarN in forum Heat PumpsReplies: 11Last Post: 20-02-2008, 04:25 PM -
No Power for Defrost Timer Motor
By kln in forum DomesticReplies: 6Last Post: 21-01-2008, 08:22 AM -
Now thats hotgas defrost for ya!
By Tycho in forum Chit Chat & Service StoriesReplies: 11Last Post: 21-09-2007, 08:28 AM -
Hotgas defrost
By Peter_1 in forum IndustrialReplies: 8Last Post: 14-03-2004, 12:47 PM
