    jenky's Avatar
    jenky Guest
    Samsung Reset/reprogramming
    I have replaced one of the the indoor units PCB of a Samsung multi-split model MH18ZA1 (A2) - 09.
    All lights flash but the unit does not work.
    Is anybody able to suggest me the required reset/reprogramming procedure either on the indoor or the outdoor unit?
    Many thanks
    Split Croatia
    6,175
    Re: Samsung Reset/reprogramming
    Quote Originally Posted by jenky View Post
    Many thanks
    This is the code: 016223-1000EA
    For description how to insert codes search this forum with "samsung" keyword
