Results 1 to 9 of 9
    Louann's Avatar
    Louann Guest
    Question Rigging a Dorm room refrigerator...
    I have a sailboat which has a basic ice locker. How can I use an old dorm room refrigerator to cool the one on my boat?
    Lou
    Aug 2008
    Englewood, CO
    23
    Re: Rigging a Dorm room refrigerator...
    An exceptionally long extension chord?
    Apr 2006
    41
    1,620
    a 300W peak inverter and good clearance for the condensor coil & a couple of good sized solar cells as the inverter will be power hungry!
    Louann's Avatar
    Louann Guest
    Lololololol!
    Louann's Avatar
    Louann Guest
    I have power on board, so power will not be an issue. I already have a refrigerator on board, but am looking to cool the ice locker as well. Is it possible to Jerry Rig parts from the dorm room fridge to work in the cooler?
    Apr 2006
    41
    1,620
    Not easily, but if you really care fully decouple the freezer plate from the old box and care fully install it in the box and not break any pipes that could work. This is based on you being lucky enough to have a dorm fridge that doesn't have the condensor embeded into the box.
    I still recommend a solar cell for good redundancy & for when your sailing you'll need to charge for some how right?
    May 2008
    66
    802
    first you need to now is how you are going to connect the tubes,because i think they will be in aluminum. second i think its best to have a fridge working on 12V or 24V,so change the compressor.check you're alternator,generator.and last but not least,if you want it to work under sailing conditions,it needs to be working under an angel of 30° or 35° sloop of the boat.
    did some sailing myself.
    Ice
    Louann's Avatar
    Louann Guest
    Thank you for all of your help. I will try my luck and let everyone know. That is unless I am extremely unsuccessful. Then I will keep it to myself! Lou
    May 2008
    66
    802
    NO ,you should tell us what you did,how you did it and if it goes wrong where it was going wrong.
    so we can learn from your succes or failure.
    thnx, Ice
  1. Heat transfer coefficient - Coolpack
    By Graham in forum Fundamentals
    Last Post: 28-05-2008, 01:08 AM
  2. Thawing Room (defrosting Room For Meat)
    By arunuae in forum Commercial
    Last Post: 09-02-2008, 09:24 AM
  3. Propane Refrigerator Conversion
    By zolar1 in forum Refrigerants
    Last Post: 04-02-2007, 03:42 AM
  4. Freezer Room Panels
    By Feeze in forum Technical Discussions
    Last Post: 22-04-2005, 05:58 AM
  5. How the refrigerator is less humid than outside
    By Abu Bakar in forum Fundamentals
    Last Post: 19-06-2003, 03:06 AM
