    Sep 2008
    malta
    5
    electolux GP12TB
    hi guys I am new to the site.. can anyone give me some help pls.? actually i am trying to solve a problem with a display bench having an electrolux GP12TB compressor which is continously burning out fuses after about 10 t0 15 min running.. I checked insulation resistance of starting and running coils and it seems to be fine but i noticed that the temp of the comp. itself is quite high while it is blowing up... pls help
    Oct 2006
    Bucks, U.K.
    71
    604
    Re: electolux GP12TB
    Hi, you need to supply more information to us.
    Have you attached gauges? High and Low side pressures? Refrigerant? Is condenser clear of obstruction? Has unit been worked on recently - ie recharged.
    What size fuse is blowing? How do you know it is compressor that is breaking down to cause the fuse to blow?
    These are a few to start with!
    Jul 2007
    Australia
    1,845
    Is the start relay disengaging?
    Sep 2008
    malta
    5
    10x anyway guys i resolved the problem the compressor was remaining on the the starting coil only...
    Jul 2007
    Australia
    1,845
    Wired up wrong or was it the relay not dis-engaging?
    Sep 2008
    malta
    5
    relay not disengaging
  1. Trimco with Electrolux GP12TB
    By squarebar in forum Commercial
    Last Post: 04-09-2008, 09:38 PM
