    Crew Chief's Avatar
    Crew Chief Guest
    R-410a Compressors
    New to this site.
    I'm in the process of designing a new air cooled chiller capable of operating at -20F/-29C brine temperatures. The unit will be air cooled and I would like to use R-410a provided I can find a suitable compressor.
    Capacity target is 10 tons /35kW at -20F/-29C.
    Can anyone recommend a compressor that's capable of this application?
    Mar 2006
    Merate (LC) - Italy
    2,549
    Not easy. 35kW at -35°C boiling point, 45 to 55°C condensing temperature and 42 bar design pressure....
    Aug 2005
    5,302
    Re: R-410a Compressors
    Why not use R-507? The pressures will be lower , which reduces some of your problems with the compressor selection but also the air-cooled condenser.
    Crew Chief's Avatar
    Crew Chief Guest
    R-507 is an option. I was trying to utilize the 410a option because I just designed a new air conditioner platform and wanted to use the same basic components. Also, R-507 requires a little more horsepower than R-410a as well as thermodynamics.
    Aug 2005
    5,302
    Quote Originally Posted by Crew Chief View Post
    OK, how much of an increase will this mean? Can you lower the condensing temperature 1° or so to compensate for it?
    Or, look at the total power (compressor + condenser fans). What kind of options can you find then?
    Air-cooled with R-410 is asking for a challenge... unless the peak ambient temperatures are low enough to allow reasonable discharge pressures.
    Mar 2005
    wisconsin usa
    55
    13
    Im not sure you will find a 410a compressor for this application. Instead of 507, I would go with 404a which is essentially the same refrigerant except that 404a has 134a added to control discharge pressure. The 134a in the mix does not affect evaporator performance much at all as it is a much lower pressure refrigerant.
    Mar 2006
    Merate (LC) - Italy
    2,549
    We've got these: http://www.frascold.it/pdf/CATALOGUES/FCAT22-01.pdf but you will need to build a rack and have liquid injection or head fan.
  1. Compressors - screw or reciprocating?
    By Josip in forum Industrial Compressors
    Last Post: 27-01-2009, 10:36 PM
  2. FES screw compressors
    By negmy13 in forum Technical Speculations
    Last Post: 08-08-2008, 07:40 AM
  3. New types of Refrigeration Compressors
    By adjohnson208 in forum New Technologies
    Last Post: 03-07-2008, 07:35 PM
  4. Do we have some expert in replacing compressors
    By Zahid in forum Air Conditioning
    Last Post: 01-07-2008, 07:59 AM
