    Jan 2008
    port elizabeth
    48
    5
    Cool Multiplex Piping
    HI GUYS JUST CURIOUS
    I HAVE A MEDIUM TEMP MULTIPLEX ON R22 USING SIX BLOWERS IN A DROP TEMP ROOM EVAPORATING @ O DEGREES C THE BLOWERS ARE SPACED SIX METERS APART AND THE LAST BLOWER IS 50 METERS AWAY FROM THE PLEX the system capacity is 150kw @0 evap what i want to know is do i run a suction and liquid header all the way to the last blower that can handle the full load or can i reducu accordingly as i get closer to the blowers
    Oct 2003
    5,630
    Re: Multiplex Piping
    After every blower you ca reduce your lines according to the capacities that can pass through the lines.
    You also can leave the liquid line in the original big size but it will cost you more refrigerant.
    Especially the oil return must sized properly.
    But you're evaporating at 0°C on R33, so this will not give you many problems . Slope suction towards the compressors anyhow.
  1. Pressure piping test
    By Volnei in forum Industrial
    Last Post: 03-07-2010, 10:30 PM
  2. Q: Piping installation for Split Types
    By brianubaldo in forum Refrigerants
    Last Post: 30-04-2008, 02:23 PM
  3. Cooling tower piping design
    By kaon in forum Technical Speculations
    Last Post: 24-01-2008, 07:00 AM
  4. Piping Advice
    By Mickvee in forum Air Conditioning
    Last Post: 11-06-2006, 03:39 PM
  5. Vibration in refrigerant piping
    By US Iceman in forum Technical Discussions
    Last Post: 01-05-2006, 11:53 PM
