Thread: Design Pressure
    mdnorthrup's Avatar
    mdnorthrup Guest
    Design Pressure
    Hello All
    What is the design pressure on a data tag of a reach-in cooler referring to? Is it what that system is designed to run at, the max pressure it can safely run at, the max pressure the system can handle before the solder joints burst?
    11,025
    Re: Design Pressure
    The design pressure is probably the safe test pressure that can be applied to the system.
    Feb 2008
    Las Vegas, NV
    67
    330
    Re: Design Pressure
    mdnorthrup,
    Check out these two links. They contain good information on design pressures.
    Tecumseh: #ER-15
    http://www.hvacrinfo.com/tech_ae_index.htm
    Copeland: Section 25, # 25-1177
    http://www.hvacrinfo.com/ae_index.htm
  1. How to Design Refrigeration Systems
    By US Iceman in forum Fundamentals
    Last Post: 24-07-2008, 04:27 PM
  2. Benji
  3. Building a wine cabinet
