Thread: Thermal fuses
    Jul 2007
    Australia
    1,845
    Thermal fuses
    Anyone made their own up?
    As most people know, it's a common fault with frost free fridges, especially samsungs.
    Anyway, I've got an interesting model samsung here with a blown thermal fuse. It's a 250L upright that is normally a timer/klixon based fridge. But this one has a sealed PCB and coil sensor so other thermal fuses won't fit the wiring loom/plug, and the supplier has told me it's a 4-6 week wait for parts to be shipped from overseas.
    I know my local electronics shop has 77*C thermal fuses, but to get it installed, I'd need to solder I guess.
    Any tips in soldering thermal fuses? Can it be done without blowing them, even if you just keep the fuse body wet while soldering?
    I would have thought if soldering was possible, the manufacturers would have done it because it's cheaper than crimping. But most seemed crimped but I don't know what type of crimp joins they've used.
    Thermal fuses are only $2 ea, so I would like to get a system/crimp connector in place to save time and money repalcing on site, rather than waiting 2 weeks+ and paying $20+ for OEM replacements.
    Oct 2006
    Bucks, U.K.
    71
    604
    Re: Thermal fuses
    Hi Paul,
    As far as I know you cannot solder these thermal fuses - sort of self-defeating!!
    I've only ever seen them crimped too. I've used a modified crimp for the purpose with some success. Use a 0.25" push on crimp and cut the body off, leaving just the barrel which you can then use as a miniature in-line crimp.
    Don't forget that the body of these thermal fuses is not insulated, so I then enclose the whole assembly in close fitting sleeving.
    The application I was using these for was for water heaters.
    Jul 2007
    Australia
    1,845
    Re: Thermal fuses
    Yeah like I said, if they could be soldered, even carefully with something to cool the fuse, they would already be, as it's cheaper for the manufacturer than crimp terminals are, so I guess that's a no go.
    DO you have any links to show the crimp terminal you are talking about?
    I was going to heatshrink the fuse afterwards.
    Oct 2006
    Bucks, U.K.
    71
    604
    Re: Thermal fuses
    Standard RED crimp terminal
    Cut off ring and use barrel to crimp wire to fuse lead
    Attached Files Attached Files
    Jul 2006
    norfolk
    737
    Re: Thermal fuses
    wot model no samsung as may have thermal fuse laying about can send ya
    Jul 2007
    Australia
    1,845
    Re: Thermal fuses
    It was that RT24 I posted about in another thread that you replied to re: service manual.
    It's no big deal, I just went and bought a $3 thermal fuse and crimped it on.
  1. Thermal Sink / storage
    By dhananjaylagwan in forum Air Conditioning
    Last Post: 29-07-2008, 08:41 AM
  2. Thermal storage system
    By Rajkumar in forum Air Conditioning
    Last Post: 13-06-2008, 06:10 AM
  3. Difference between geo thermal and air to air
    By ianybeany in forum Heat Pumps
    Last Post: 23-02-2008, 11:15 PM
  4. thermal Overload
    By marc5180 in forum Trouble Shooting
    Last Post: 03-11-2007, 10:25 PM
  5. Thermal Efficiency of Refrigeration System
    By hussain316 in forum Refrigeration Books
    Last Post: 31-07-2007, 08:59 PM
