Thread: Ranco K14 replacement
29-08-2008, 11:51 AM #1
I have a MAXI 310 beer cooler. The K14 P0130 thermostat has failed so I am after a replacement. I have been unable to find any info on this model. I was hoping to fit a variable type eg a K50 P1118 (may be?) or some other type that is available as I cannot source the K14 or the K50 anywhere.
Can anybody help?
29-08-2008, 04:49 PM #2
Re: Ranco K14 replacement
HI STURGM
You can contact ranco on the following link.
mailto:customer.care@invensyscontrols.com
They will advise you of your nearest supplier.
Alternative options are as follows.
http://www.invensyscontrolseurope.co...MOSTATSBri.pdf
Cheers GrizzlyLast edited by Grizzly; 29-08-2008 at 07:23 PM.
29-08-2008, 05:13 PM #3
Why wont you replace it with digital temp controller such as
Dixell XR 20CX or Eliwell 961?
30-08-2008, 06:09 PM #4
Thanks for the info I have orderd a couple of K series and will give them a go
R22 replacement
By brad__34 in forum RefrigerantsReplies: 28Last Post: 04-06-2010, 09:06 PM -
Ranco thermostats and ice machines
By Andy W in forum CommercialReplies: 33Last Post: 31-01-2010, 12:43 PM -
HFC Replacement for r22 in flooded system
By kevinM in forum RefrigerantsReplies: 8Last Post: 26-03-2008, 02:02 PM -
Replacement Screw Compressors
By dkemper in forum Technical DiscussionsReplies: 2Last Post: 13-10-2007, 07:22 PM -
F 11 replacement for flushing
By andrewuk in forum RefrigerantsReplies: 1Last Post: 17-10-2003, 11:03 PM
