    Nov 2007
    Jakarta
    75
    11
    Cutting device for Tube ice
    Dear Buddies,
    I need your help for design of a device or tools for cutting tube ice during its harvesting (by using hot gas).
    Thank you very much for your help and kind attention.
    Jun 2006
    jiansu
    38
    Re: Cutting device for Tube ice
    Dear maguro4448,
    Sorry , I don't know what your mean.
    As usually, tube ice machine has it's cutting tube ice device.
    Nov 2007
    Jakarta
    75
    11
    Dear ntfreezer,
    Yes you right each unit tube ice has it's cutting device. Do you have design or drawing of this cutting device, as I need to make drawing for my dissertation.
    Thank you for your attention
    Regards,
    Maguro4448
    Mar 2006
    dallas, texas
    75
    108
    most of the companies that manufacturer an ice maker have a propritary design for the cutter.
    But it is really pretty simple ,
    It is a rotating set of blades and a slinger all mounted on a rotating table.
    this is usually shaft driven with a top and bottom bearing with a belt drive below to a outboard mounted electric drive
    Most are preset for the ice cube lengh before shipment .
    Bruce
    Nov 2007
    Jakarta
    75
    11
    Dear bruceboldy,
    Thank you very much for your information for the device.
    I will try to make the design.
    Regards.
  1. Cutting Corners
    By eggman08.2008 in forum Technical Discussions
    Last Post: 05-07-2008, 06:25 PM
  2. no metering device
    By Richvacr in forum Commercial
    Last Post: 05-06-2008, 02:40 PM
  3. Cutting unistrut
    By Andy AC in forum Tools and Calculators
    Last Post: 27-05-2007, 09:32 PM
  4. Protection device
    By petre11 in forum Electrical
    Last Post: 06-06-2006, 11:23 PM
  5. Energy Managment XDX Device
    By Steve Wright in forum Supermarket Refrigeration
    Last Post: 08-09-2005, 06:19 PM
