Thread: 410A guages which type?
28-08-2008, 09:43 AM #1
Hi guys, just about to order a set of 410A guages, but just noticed in HRP book you can either have bourden type or bellows type, does it matter either/either, what would the different applications be..
Cheers nick..
28-08-2008, 10:07 AM #2
Re: 410A guages which type?
Go electronic and the gauges will do all the work for you. You can get electronic ones that work all the refrigerants on the market at the moment.
The differance between bourdon tube and bellows is only in the linkages that conect the tube / bellow to the dial. The one thing to take into consideration with the bourdon tube is that it can be deformed if left under great pressure for long periods of time. So if you are pressure testing and leave your gauges under pressure for hours on end the bourdon tube can distort and throw the gauge out of callibration.
Cheers taz
28-08-2008, 11:20 AM #3
Cheers taz, bellows it is then, as per electronic guages have found all singing all dancing set, but at £80 more ex than normal guages boss is holding off for a while...
Nick..
28-08-2008, 07:52 PM #4
The Mastercool 33636-EBC2 is a good seller as well as the Q196 Refco Clim set.
28-08-2008, 08:13 PM #5
Just out of intrest why would you go electronic instead of traditional gauges
01-09-2008, 03:35 PM #6
Just a quick reply to all, spent the extra cash and went for a mastercool set of guages..Bloody brilliant piece of kit, would recomend them to anyone..
Nick..
01-09-2008, 05:27 PM #7
To begin with analog gauges be they Bourdon tube or bellows, dry or glycerin are inaccurate before you ever remove them from the box they are shipped in, so accuracy should be enough to encourage anyone serious about the trade to transition away from "traditional" to digitals. Reliability, durability and versatility are a few more.
Outside of a few places on the internet it is not apparent - but the digital manifold gauge is greatly expanding the application parameters of the manifold gauge. Acquisition of pressure values is but a small part of the capabilities of new generation digitals. You also do not have calculation errors when converting your pressures to superheat/subcooling values with digitals because digitals eliminate the need to do these calculations.Ours is a world of nuclear giants and ethical infants. If we continue to develop our technology without wisdom or prudence, our servant may prove to be our executioner.
410a charging
By gwilliamson in forum Air ConditioningReplies: 39Last Post: 17-11-2010, 06:03 AM -
breaker type?
By tait71 in forum ElectricalReplies: 24Last Post: 05-09-2010, 04:39 AM -
Testo digital guages
By marc5180 in forum Tools and CalculatorsReplies: 8Last Post: 02-09-2008, 07:48 PM -
earth leakage
By sid in forum ElectricalReplies: 33Last Post: 11-07-2008, 07:58 PM -
Flake type ice maker
By vinod in forum Technical DiscussionsReplies: 0Last Post: 25-04-2008, 08:26 AM
