Thread: Big size Ammonia Valve
27-08-2008, 11:31 PM #1
Dear friends
What kind of shut off valves do you advise for 16,18 20 In diameter
Please recomend manufacturer
28-08-2008, 12:04 AM #2
Re: Big size Ammonia Valve
I like the following hi-performance butterfly valves...
Xomox
http://www.xomox.com/Xomox/htdocs/index.html
Neles-Jamesbury
http://www.jamesbury.com/public/defaultframe.asp?amp;
I've used both.
PS. Insist on hi-performance valves though and not the cheaper variety other manufacturers may offer.If all else fails, ask for help.
28-08-2008, 10:16 AM #3
dear,
you can look :http://www.worldbase.cn/product3.html
We can supply high quality cheap price ammonia valve.
28-08-2008, 03:09 PM #4
Thanks US ICEMAN/NT Freezer
You know the Herl (Parker) valves are very nice but in their catalog only have untill 14 "
I know their valves have all certificated and test for ammonia also Fire Protection Association .
Normally for these big valves we have to use butterfly valves due to the weight. However nowtodays the globe valves are make lighter
The installacion of butterfly valves should be made carefully .The welder could burn the seal
I thanks again
Gwapa
28-08-2008, 03:39 PM #5
Originally Posted by gwapaIf all else fails, ask for help.
size capillary for any application & refrigerant
By benijoseph in forum Technical SpeculationsReplies: 12Last Post: 07-06-2009, 10:00 AM -
Releasing ammonia into the environment.
By Tycho in forum NH3Replies: 21Last Post: 03-02-2008, 05:10 PM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
Expansion valve oriface size
By sling 1000 in forum FundamentalsReplies: 4Last Post: 06-09-2007, 03:42 PM -
Need a correctly sized valve
By Abe in forum CommercialReplies: 2Last Post: 26-10-2005, 08:42 PM
