Results 1 to 2 of 2
Thread: Frigoscandia LSV system
27-08-2008, 11:42 AM #1
http://www.badongo.com/file/11072841
As I can see there is not much difference between the flooded system with Accumulator & this system. Any Comments. has any one installed this?
30-08-2008, 12:23 AM #2
Re: Frigoscandia LSV system
Overfeed systems and LVS are totally different, LVS has no pump and no accumulator, LVS is high pressure sub-cooled liquid feed to evap, for high flow regeneration flow through coil. If you cannot see the difference. You have a problem.
magoo
Daikin fault codes
By Chris2005 in forum Air ConditioningReplies: 45Last Post: 21-03-2012, 10:09 PM -
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
System Burn Out Troubleshooting
By altaf22m in forum Technical DiscussionsReplies: 13Last Post: 07-05-2010, 09:24 AM -
Burn out System, Clean up procedure. & Troubleshooting.
By altaf22m in forum CommercialReplies: 19Last Post: 15-04-2008, 07:03 PM
