Results 1 to 9 of 9
    ACEngineer700's Avatar
    ACEngineer700 Guest
    Hello,
    Can anyone help me with working out running costs for a VRF/VRV system? Any calculations would be a great help.
    Oct 2001
    Nottingham UK
    5,668
    Re: VRF Running Costs
    Sure........
    Just post some details to allow some calcs to be done, such as:
    Outdoor running amps
    total indoor running amps
    total daily operating hours - indoor and outdoor
    price of energy paid
    number of days system running per year
    etc..
    ACEngineer700 Guest
    Normally I would use the calculation (Power Input x Hours per Annum) x £0.10 as electricity costs, for both indoors and outdoor units. By doing this I have come up with some very high results. fficeffice" />>>
    Outdoor running amps = Total current 15.6A or Power input
    Total indoor running amps = Current at 0.16A or Power Input at 32.6W x 10
    Total daily operating hours - indoor and outdoor = 8 hours
    Price of energy paid = £0.10
    Number of days system running per year = Call it one day for now.>>
    Would you factor in for the fact that the system will not be running at full power all day?>>
    Nov 2007
    Scotland
    67
    141
    Either that or talk to one of the suppliers, Daikin,Mitsi etc who will usually do it quite quickly for you if there is a good possibility of a sale!
    Oct 2001
    Nottingham UK
    5,668
    So, for 1 day
    Indoor unit: 10 No.
    Assuming that the units are on single phase:
    ((0.16A x 10 x 240v)/1000) x 8 hrs x £0.10 = £0.31
    Outdoor Unit: 1 No.
    Assuming that the unit is on 3 phase 415v:
    ((15.6A x 1 x 720)/1000) x (8hrs x 0.75) x £0.10 = £6.74
    The 0.75 assumes that the outdoor compressor only runs for 6 out of the 8 hours.
    Now, if the compressor is inverter driven you will have to either apply a factor or work out an average amp draw and substitute that figure in place of the full load current.
    Mar 2007
    Warwickshire UK
    723
    21
    A basic concept of VRF is heat recovery potential.
    3 pipe systems & ME City Multi R2.
    So if some units are in cooling & some in heating the system provides direct heat transfer from the units cooling to the units heating.
    Do you want to factor this energy recovery into you running cost estimate ?
    ACEngineer700 Guest
    The reason for my delayed reply is that I have been on holiday….fficeffice" />>>
    Thanks for all you help its been a great help.>>
    NZPRO's Avatar
    NZPRO Guest
    No Body head of PPD Power proportional Distribution
    Apr 2004
    Pakistan
    44
    129
    21
    Simple power calculation formulae
    P(kilo Watt)=I(ampere)XV(volts)/1000
    and multiply above by 1.732 that is square root of 3 in case of 3 phase.
    I would be obliged if someone can send me comparison of 10 ton system on
    1. Air cooled chiller with boiler in winter with FCU as indoor.
    2.Multi digital VRF system based on scroll system.
    3. conventional wall mounted split system.
    I need above three comparisons with initial/running and payback costs.
    Our nose is our personal air-conditioning system: it warms cold air, cools hot air and filters impurities
  1. Problems with compressor running too cold
    By abrando1 in forum Trouble Shooting
    Last Post: 12-05-2009, 10:08 PM
  2. Walkin cooler running to warm need help
    By The Butcher in forum Trouble Shooting
    Last Post: 03-08-2007, 09:19 PM
  3. Running Costs
    By Abe in forum Air Conditioning
    Last Post: 09-04-2007, 12:58 AM
  4. running costs
    By refaircon in forum Air Conditioning
    Last Post: 14-01-2007, 09:01 PM
  5. Electric costs running an air conditioner
    Last Post: 05-08-2003, 10:10 PM
