    Aug 2008
    Reading
    26
    Is there a 24V water chiller? Around 300W?
    Hi guys,
    I'm looking for a recirculating water chiller as part of a hybrid ventilation system.
    It needs to be able to deliver around 300W of cooling and the plan is to run it from two 150W solar panels. So preferably it needs to be 24V DC. We need temperatures down to around 10C at room temperature.
    Any ideas????
    11,025
    Re: Is there a 24V water chiller? Around 300W?
    You could have a look at the Danfoss 12-24vdc compressors....
    http://de.refrignet.danfoss.com/Tech..._pb100d202.pdf
    Also, information here...
    http://compressors.danfoss.com/products/products_dc.htm
    Aug 2008
    Reading
    26
    Thanks very much- I'll check it out.
    May 2008
    66
    802
    is this something that has to be build yet??
    if so,i would like to now the outcome.
    i am also scribbling around on paper,but never have enough time or money to build.
    Ice
    Sep 2005
    42
    191
    I'd recommend something like this... ebay link
    they're totally inefficient.. them move 1watt of heat for every 1watt of power put in (which means for every 1 watt of heat absorbed by the cold side you have to remove 2 from the hot side!)
    but they'll run right from you're soler panels, if they're only putting out 10% power then they'll still work... unlike a compressor
  1. water chiller question
    By chillman in forum Technical Speculations
    Last Post: 12-03-2008, 09:21 PM
  2. Water Chiller
    By lana in forum Technical Speculations
    Last Post: 23-06-2007, 01:19 AM
  3. Water chiller help
    By ultralo1 in forum Trouble Shooting
    Last Post: 12-05-2007, 11:52 AM
  4. Connecting Trane Water chiller to air handling unit
    By celtictech in forum Fundamentals
    Last Post: 08-03-2007, 06:14 PM
  5. Building a wine cabinet
Tags for this Thread
