Thread: Summer time nightmare
26-08-2008, 05:19 AM #1
Imagine this if you would. Your plants down and every pressure relief valve has to be replaced and all the plumbing attatched to it. So we have contractors come in to do this choir. 1:30 in the afternoon your bleeding out the liquid side of a thermosypon. So the srv's can be changed. Then bam contractor takes off the WRONG srv valve and now you got your second stage pouring out of a 1.25 inch hole. Now you can thank god that you had to bleed that out a week ago and only had some residual gas build up in it......... Couple days later...... (scratches head) We evacuated a thermosypon cooler and it had been open for a couple of days then the return line seat on the valve let go..... Again pouring wet gas out........ Glad to be back up and running now.
26-08-2008, 07:35 PM #2
Re: Summer time nightmare
What?
26-08-2008, 10:09 PM #3
I guess the cheapest price may not always be the best.
27-08-2008, 05:26 AM #4
15-09-2008, 04:51 AM #5
If it doesnt you will surely know it! I like to loosen the manway bolt very slowly and break the seal while plenty of thread is still visible! With a mask on of course! Never trust a valve! I am lucky! In my plant we have a pump out system and our SOPs allow some time to monitor pressure before the vessel is opened.
26-09-2008, 11:23 PM #6
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
TK basic micro-p features and functions
By REEFER-TEK in forum TransportReplies: 0Last Post: 05-12-2007, 06:25 PM -
what do you do on your off time?
By Tycho in forum Chit Chat & Service StoriesReplies: 15Last Post: 09-10-2006, 12:03 AM -
Time delay for multi compressors
By iceman007 in forum Air ConditioningReplies: 5Last Post: 06-11-2004, 08:05 AM
