Thread: How to design this...
26-08-2008, 02:12 AM #1
i need to design a refrigeration system wherein
Te = from -20C up to -10C
RC = from 20 tons to 40 tons
and should have a 2-compressor setup...
this can use flash tank or intercooler but i prefer to use an intercooler
tnx!
26-08-2008, 02:24 AM #2
Re: How to design this...
A flash tank is normally different from an intercooler.
A flash tank is usually used for providing cold liquid at some intermediate temperature for lower temperature evaporators.
An intercooler is used to desuperheat the low stage discharge gas befor ethe vapor enters the high stage compressor.
However, there are flash type intercoolers also...If all else fails, ask for help.
26-08-2008, 02:43 PM #3
i forgot to specify that the intercooler will use a heat exchanger using water as the coolant
What design factors decides power comsumption
By kln in forum DomesticReplies: 3Last Post: 28-01-2008, 08:29 PM -
Efficient Water-Source Condenser Design?
By Enginerd in forum FundamentalsReplies: 4Last Post: 28-05-2007, 05:11 AM -
Replacement fo CO2 Bulk Tank refrigeration unit
By pabs_ref in forum CO2Replies: 31Last Post: 28-11-2006, 10:32 PM -
How to Design Refrigerated Cabinets
By Rayin in forum FundamentalsReplies: 5Last Post: 26-11-2006, 08:27 AM
