Threaded View
25-08-2008, 08:28 PM #1
Hanbell Screw Compressor Not Loading
Hi Guys, Just new in this forum I just want to ask all the expert in Hanbell Screw Compressor. I have a new 3 chillers with 2 hanbell screw compressor each. All the compressor is not loading to 100% even the 4 steps of loading is reach. The chiller refrigerant is 134-a the amp draw up to 53% only. All the controller, design water flow rate, pressure drop across the evaporator and condenser, sequence of loading and the compressor parameters are normal (subcooling, superheat and split temp. accros the evap. and condenser).
Thank you very much
God Bless
VSD on screw machines
By Mike Hopkins in forum New TechnologiesReplies: 14Last Post: 20-02-2011, 12:10 AM -
Compressors - screw or reciprocating?
By Josip in forum Industrial CompressorsReplies: 18Last Post: 27-01-2009, 10:36 PM -
advantage of twin screw compressor over single screw compressor
By azzah in forum New to REReplies: 7Last Post: 23-09-2008, 09:24 AM -
Autoloading slide valve for Screw compressor
By screw_geek in forum Industrial CompressorsReplies: 32Last Post: 04-04-2008, 03:47 AM -
Mono or twin screw
By Nirmalya in forum Industrial CompressorsReplies: 43Last Post: 12-09-2006, 03:19 AM
