    Dec 2005
    uae
    54
    30 gh pro dialog plus chiller (Carrier)
    Hi;
    30 GH chiller showing fault code 40,41,47,46,103,203.
    Replaced the exv motor ,pressure transaduser,sensor of both circute.
    still the chilller is tripping . somebody can help please?
    Aug 2007
    Adelaide Australia
    70
    562
    Re: 30 gh pro dialog plus chiller (Carrier)
    Hi vinod
    Are you still getting the same fault codes after changing all the listed parts.
    103 and 203 are HP trips on circuit 1 and 2. Have you checked the driers and are all the condenser fans running.
    Blocked driers can bring up 46 & 47.
    Paul
    Dec 2001
    137
    Not sure if they are right for the 30GH but for the 30GX the codes are as follows.
    103 - Compressor A1 current imbalance >10%
    203 - Compressor A2 current imbalance >10%
    46 - Oil solenoid failure compressor A1. oil pd > 17kPa
    47 - Oil solenoid failure compressor A1. oil pd > 17kPa
    41 - loss of communications with analogue card
    40 - loss of communications with fan card
    Brit
    Jun 2008
    chuyer
    Hello,
    30GH's codes are not the same with 30 GX because the softs are different.
    For help me, Your display PRO DIALOG is Black or Grey?
    Mar 2006
    Greece
    Hi Vinod, alarm # 46 & 47 indicate a need to check the oil solanoid valves. Sometimes they remain partly open due to some dirt.
    Mar 2009
    Goodlands
    44
    9
    hi did you try change the exv board ,
    May 2008
    66
    802
    is it possible to take some note's of the temps and pressure wile its working???
    mabey couse of an unbalance in current the comps are not functioning like they should, and therefore give an unbalanced refrig isue, whitch cause an constand tripping on security's.
    just some loud thingking.
    Ice
    PPaul's Avatar
    PPaul Guest
    Can I have the wiring diagram of Prodiolog chiller 30GH 245?
    Thank You
  1. Replies: 12
  2. Carrier chiller basic board problem
    By noushad123 in forum Trouble Shooting
    Last Post: 17-06-2010, 06:55 AM
  3. Carrier Pro Dialog Plus help
    By borodave1973 in forum Air Conditioning
    Last Post: 11-11-2007, 06:47 PM
  4. Carrier Chiller Help
    By superswill in forum Trouble Shooting
    Last Post: 18-01-2007, 10:06 PM
  5. Carrier chiller oil migration
    By lowtech in forum Industrial
    Last Post: 30-04-2006, 04:11 PM
