Thread: water cooled condenser
18-08-2008, 08:42 PM #1
Been asked to jump on an 11th hour job.
Customer requires a twin split ....14 kw cooling with a water cooled condenser .... condenser water supplied from landlords ring main.
I have been told that mitsy elec do a 8hp about 20kw unit, but you can put put two 8kw cassettes on and they will work fine.
Going to start looking into it tomorrow.
Can anyone give me a head start
thanks in advance
Dave
18-08-2008, 10:57 PM #2
Re: water cooled condenser
Other options, but probably as expensive is a carrier 07KD060 with two 40KMC036 cassettes on a twin application or a clivet MCH51 with twin Marstair CC875-80 cassettes.
In each case the units have to be in the same space and operating as a single unit.
There is also the Daikin VRV-W11 RWEYQ10M with 2 FXFQP-80 cassettes for individual control.
Brit
19-08-2008, 06:43 PM #3
Condenser water causing corrosion
By 750 Valve in forum Technical DiscussionsReplies: 7Last Post: 28-05-2008, 10:21 AM -
Making a simple water cooled condenser
By The MG Pony in forum FundamentalsReplies: 19Last Post: 01-08-2007, 11:02 AM -
How to adjust head on a water cooled condenser
By kengineering in forum Technical SpeculationsReplies: 5Last Post: 30-05-2007, 10:37 PM -
water cooled condenser shell type
By abbasi in forum New TechnologiesReplies: 0Last Post: 27-04-2005, 08:32 AM -
Building a wine cabinet
