    May 2008
    170
    F gas compliance again
    Evening,
    Can anyone tell me what is the minimum information required to be kept about equipment with F gases in. For our service customers should both party's keep a record, would model/ serial numbers and refrigerant amounts be enough. Service reports will show that leak checks have been carried out.
    If anyone has an example document I would love to peruse it.
    Oct 2003
    5,630
    34
    Re: F gas compliance again
    You need a logbook at your client where every handling with the refrigerant must be registered, a logbook for the refrigerant in your van, and a logbook in your shop.
    That's at least the situation in Belgium but I suppose it will be the same in the UK.
    Service records which states that a leak check was performed is not sufficient I think.
    You must also state that you haven't found any leaks or that you repaired those you found.
    If you found a leak, then you have to go back to re-check again.
    Aug 2001
    1,046
    All the gen you need:
    BERR’s F Gas website:
    http://www.berr.gov.uk/sectors/susta...page28889.html
    BERR’s ODS website:
    http://www.berr.gov.uk/sectors/susta...page29091.html
    DEFRA’s website deals with both F gas and ODS:
    http://www.defra.gov.uk/environment/...fgas/index.htm
    DEFRA’s site contains information on compliance, but it’s not very well laid out – this means that you have to seek out the information for yourself….
    But it’s all there…..
    Aug 2001
    1,046
    All the gen you need for the UK:
    BERR’s ODS website:
    DEFRA’s site contains information on compliance, but in my opinion it’s not very well laid out – this means that you have to seek out the information for yourself….
    However, it does contain a sample log sheet, but I would advise against cribbing the sample here. You need to do your own that is tailored to your client.
  1. F-Gas leak testing compliance?
    By sinewave in forum Air Conditioning
    Last Post: 18-06-2008, 01:00 PM
  2. scroll compressors
    By afak in forum Technical Speculations
    Last Post: 20-10-2007, 01:20 AM
  3. Earth continuity
    By bernard in forum Electrical
    Last Post: 04-04-2005, 06:35 PM
  4. HSE Compliance for HVACR contractors
    By cooltrain in forum Training
    Last Post: 30-08-2003, 10:35 AM
