Results 1 to 10 of 10
18-08-2008, 06:31 PM #1
Liquid Nitrogen to Refrigeration!!
Hello, I have a 9' liquid nitrogen cooling tunnel. I want to disregard that. I want to intall conventional refrigeration to cool cookie doe. Going in at 49 F. Want to get it to 33 F. The most time we can give the conveyer is 5 minutes thru the tunnel (9'). My thought is to have a "walk in like" tunnel built on top of the existing conveyer and add refrigeration...what do you think. can it be done?
18-08-2008, 07:38 PM #2
Re: Liquid Nitrogen to Refrigeration!!
I'm curious as to why you want to change something that works. Is this change being contemplated due to the cost of nitrogen, or something else?
5 minutes is not a lot of time to cool something.If all else fails, ask for help.
18-08-2008, 09:26 PM #3
I've done some small research on this.
I'm also curious why you want to change it.
Very important factor: how many cookies do you want to cool/hour?
Like USIceman said, it could be that your tunnel will be too small to do this.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
19-08-2008, 01:41 PM #4
how to use Liquid Nitrogen in home air-conditioner it possible please tell
19-08-2008, 01:51 PM #5
how to desine home air conditioner coil temp-is (-0 f ) in 5mintplease tell
19-08-2008, 04:12 PM #6
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
19-08-2008, 04:19 PM #7
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
19-08-2008, 07:10 PM #8
You install a liquid nitrogen reservoir outside the building.
You then connect a tube of 2 " to it inside your house at the ceiling.
At the end you install some nitrogen nozzles.
You open the valve on the reservoir and that's it.
Oh, don't forget to wear protective clothing and a oxygen mask.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
19-08-2008, 07:20 PM #9
Originally Posted by Peter
Where do these questions come from?If all else fails, ask for help.
19-08-2008, 11:27 PM #10
Actually it sounds very, very cool. If you get our drift
advanced refrigeration technology
By Lc_shi in forum FundamentalsReplies: 10Last Post: 16-02-2011, 05:22 PM -
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM -
Parker levels in ammonia systems
By Friobernal in forum IndustrialReplies: 3Last Post: 04-08-2005, 03:46 PM
