Thread: Copeland Scrolls going to earth
01-08-2008, 08:37 PM #1
Evening all,
Dont have specifics so bare with me but has anyone else had problems with NEW copeland scrolls going to earth. One of my collegues has fitted 2 in the last week and both have gone down, going straight to earth after a couple of days. System has all the usual protection devises, pressure switches, overloads, timers set a 2 mins, system clean so genuinely think its a fault with the compressors.
Anyone else had a problem.
Fatboy
Update:- The engineer has just texted me, the compressor is a ZS56K4ELast edited by Latte; 02-08-2008 at 12:37 AM. Reason: Updated info
01-08-2008, 09:57 PM #2
Re: Copeland Scrolls going to earth
Have they got phase rotation devices?
Multisync
London
01-08-2008, 10:05 PM #3
Not as far as i am aware, although i am going to site on monday with another compressor to have a look.
From what i am being told and from memory when i last went there for another job its a fairly basic condensing unit feeding 2 remote multidecks that are individually conttrolled hence the timer. What is youre thinking, they are running the wrong way or phase device running it the wrong way
Fatboy
02-08-2008, 02:44 PM #4
rdocwra,
Here's a link to Copelands AE bulletins. Check out Section 4, bulletin 4-1299. There's good information here that might help you out.
http://www.hvacrinfo.com/ae_index.htm
04-08-2008, 07:30 PM #5
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Hi, Rdocwra
Does these compressors are part of newly installed system, or they are installed after original compressors are burned-out?
06-08-2008, 01:21 PM #6
Hi, Rdocwra
I guess this compressor works on 380V! One reason this problem could appear is working long time on low voltage. That happened to me couple of times. Normaly on the machines i install a phase control/low voltage device to protect compressors
12-08-2008, 03:41 PM #7
Regarding the going the wrong way idea, you would know if they were as they don't pump correctly & they make a terrible 'bag of bolts' type of noise!
Trust me, once heard, never forgotten!
19-08-2008, 09:08 PM #8
Did anyone check the amps after the change out
newbie earth bonding
By dave_k in forum ElectricalReplies: 10Last Post: 06-05-2008, 12:37 AM -
Earth faults
By reggie in forum Technical SpeculationsReplies: 17Last Post: 28-01-2006, 06:22 PM -
Earth tapped transformers
By phil68 in forum FundamentalsReplies: 6Last Post: 04-01-2006, 09:32 PM -
Earth continuity
By bernard in forum ElectricalReplies: 3Last Post: 04-04-2005, 06:35 PM
