Thread: gas leak error
Hybrid View
17-08-2008, 11:13 AM #1
gas leak error
Hello,
I have a Samsung AC, model AQV12VBAN and recently displayed error E554 which means gas leak error.
I have stoped the AC and started it again. Now it works, but it doesn't cool.
My question is if this E554 is just an error or he is really out of gas? When I touch the pipe installation that leads to the outdoor unit its cold.
If it is just an error can I correct this in some manner, because I have to wait long time before someone will come to fix it.
Thank you
17-08-2008, 11:24 AM #2
17-08-2008, 02:43 PM #3
Re: gas leak error
Dear,
You have gas leake problem ...you shoud be loacket the leakage and than fix it and Recharged with suefacent refregerant,
Thanks.
17-08-2008, 04:04 PM #4
Re: gas leak error
Why you have to wait a long time before someone comes to fix it?
If the machine is giving an error, then you have to check if this error is really an error.
It's not because it's felling cold that the system is running like it should be.
You have to hook up a manifold and read the right running pressures. Inly this can tell you if you have gas shortage.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
17-08-2008, 04:33 PM #5
17-08-2008, 04:45 PM #6
Re: gas leak error
If there's a gas shortage, then you can' reset this.
Warranty or not, they have to come to repair the equipment they installed. Did a tirth party installed this?
If we should do this here, then our business shouldn't last very long.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
Leak detectors
By Temprite in forum Tools and CalculatorsReplies: 54Last Post: 18-08-2010, 04:15 PM -
shining fault codes
By al in forum Air ConditioningReplies: 3Last Post: 17-07-2010, 08:34 AM -
which compressor is the best?
By cakabo28 in forum New TechnologiesReplies: 33Last Post: 19-08-2009, 06:44 PM -
Evasive gas leak
By Feeze in forum Technical DiscussionsReplies: 24Last Post: 18-08-2008, 07:22 AM
