Thread: CO2 bulk tank evaporator
15-08-2008, 02:28 PM #1
I'm in the process of designing a CO2 bulk tank and I'm having trouble obtaining an evaporator coil. I'm close to choosing the condensing unit I want to use.
Is there a company out there that will design a coil for me based on the condensing unit and space constraints I have?
Thanks in advance!
15-08-2008, 05:09 PM #2
Re: CO2 bulk tank evaporator
You might try these guys...
http://www.srcoils.com/If all else fails, ask for help.
16-02-2010, 05:11 PM #3
16-02-2010, 07:46 PM #4
You can achieve as good a result using a thermosyphon system, a brazed plate heat exchanger, on the top of the tank. I have used many SWEP PHE for CO2 liquification.
Make sure vapour line enteres the vessel and not just welded to the shell. (non condesables)
Superheat and Subcooling
CO2 Bulk tank
By guapo in forum CO2Replies: 7Last Post: 10-03-2009, 12:46 PM -
Evaporator TD for Bulk milk coolers
By tadipatrir in forum CommercialReplies: 8Last Post: 01-09-2007, 05:16 PM -
bulk tank
By milton in forum Trouble ShootingReplies: 0Last Post: 04-02-2007, 12:11 PM -
evaporator tank milk
By milton in forum Trouble ShootingReplies: 2Last Post: 22-06-2006, 09:18 PM
