    Aug 2008
    Chicago, IL
    11
    CO2 bulk tank evaporator
    I'm in the process of designing a CO2 bulk tank and I'm having trouble obtaining an evaporator coil. I'm close to choosing the condensing unit I want to use.
    Is there a company out there that will design a coil for me based on the condensing unit and space constraints I have?
    Thanks in advance!
    Aug 2005
    5,327
    Re: CO2 bulk tank evaporator
    You might try these guys...
    http://www.srcoils.com/
    Bruce Scheiman's Avatar
    Bruce Scheiman Guest
    Quote Originally Posted by MechEng1 View Post
    Thanks in advance!
    I also need to have a coil design for a bulk CO2 tank. Did you ever find someone to support your need? Super Radiator could not help.
    Aug 2009
    New Zealand
    54
    2,556
    You can achieve as good a result using a thermosyphon system, a brazed plate heat exchanger, on the top of the tank. I have used many SWEP PHE for CO2 liquification.
    Make sure vapour line enteres the vessel and not just welded to the shell. (non condesables)
  1. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  2. CO2 Bulk tank
    By guapo in forum CO2
    Last Post: 10-03-2009, 12:46 PM
  3. Evaporator TD for Bulk milk coolers
    By tadipatrir in forum Commercial
    Last Post: 01-09-2007, 05:16 PM
  4. bulk tank
    By milton in forum Trouble Shooting
    Last Post: 04-02-2007, 12:11 PM
  5. evaporator tank milk
    Last Post: 22-06-2006, 09:18 PM
