Results 1 to 2 of 2
13-08-2008, 03:24 PM #1
Accidentally mixed R404A with R134a
Dear All,
We had compressor Danfoss MTZ28-4 for food chiller using R404A. Unfortunately our team member did not realize that the compressor is use R404A, he took R134A which we use for our HVAC system to recharge the food chiller. After desired suction pressure reached then he just realize he made mistaken. Now our food chiller still opreating, but cannot reach temperature setting (0-5 degC)? What would happen with our chiller system? Can we recharge it again with R404A to make the lower temperature? Thank you
13-08-2008, 03:33 PM #2
Re: Accidentally mixed R404A with R134a
Remove wrong refrigerant as much as possible with recovery unit and restart with the right refrigerant. Vacuum is not necessary because R404a consists of R134a.
It will never work and your TEV or capillary is not designed for this refrigerant.
If you want to destroy your compressor, let it run this way.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
R507 in an R134a compressor: any danger?
By DaBit in forum Technical SpeculationsReplies: 30Last Post: 21-12-2009, 12:44 AM -
R134a Vs R404A
By Julia in forum RefrigerantsReplies: 2Last Post: 20-09-2007, 07:30 PM -
R134a or R404a
By jingua_ph in forum RefrigerantsReplies: 4Last Post: 27-09-2006, 03:31 PM -
Pressure Transmitter R134a Setpoints
By cooltrain in forum Technical SpeculationsReplies: 0Last Post: 28-02-2005, 09:05 AM -
Is there anything about R134a that is better than R12?
By dude in forum RefrigerantsReplies: 5Last Post: 01-03-2004, 09:59 PM
