Results 1 to 10 of 10
Thread: Questions about R-170 (Ethane)
13-08-2008, 08:10 AM #1
Hi, all.
Our company got order of R290/R170 cascade refrigeration package. However, it's the first time to use R170 as a refrigerant, so your helps are needed.
1) Is there minimum degree of purity to use R170 as a refrigerant?
2) We have experience of using CO2 as low side refrigerant of cascade system. Any noticeable difference for design or operating between CO2 and R170?
3) It's hard to find R-170 supplier. Would you recommend R-170 world wide supplier? The product to be exported to South Korea.
Thanks in advance.
13-08-2008, 07:55 PM #2
Re: Questions about R-170 (Ethane)
Ironicaly you'll get the most detailed practical experiance by the computer over clocking community atm.
13-08-2008, 07:56 PM #3
Okay, first off, ethane vs co2 is a wonderful new experience for you. Oil becomes much easier in the system, pressures will be a tid bit higher, and ultimately you'll have much better load and temperature handling. Also you can use a economizer without fears of dry ice, which will earn you 10-15% with ethane.
1) I'd recommend 99.5% or better, and charging through a large 3-5 ton filter if you have one handy.
2) See above.
3) Airgas?
14-08-2008, 01:51 AM #4
Thanks a lot Pony and NoL...
27-08-2008, 10:26 AM #5
05-02-2010, 07:26 PM #6
does anyone know where i can find a PT Chart for R170????
05-02-2010, 07:54 PM #7
Hi you can buy it here for $5
http://appshopper.com/productivity/r...pressure-chart
NormMy wife used to say you never listen to a word I say at least I think that what she said
05-02-2010, 08:22 PM #8
any charts for it online that i can possibly print?
06-02-2010, 06:25 PM #9
09-02-2010, 12:42 PM #10
Hi from cold Norway.
You could ask the Ilshin company in Korea.
They are a big maker of ultralow temperature freezers and they use mostly R 170 in the low side og their systems. I suppose they import a lot of the stuff. Not a big deal, but if you get the it as a refrigerant labeled as R 170 is should be pure and dry just to use. No need for any filtration then. I am into the R1150 an even more flamable type (Ethen formerly ethylene) and that one was supplied cheap by a gas suplier normally used as a ripening gas. Not speced as an R gas, but still very dry and clean so may be some other branches use a good ethen you can use.
R 170 Ethane
By fridgey in forum RefrigerantsReplies: 10Last Post: 30-07-2009, 01:22 PM -
Interview questions
By zimbo in forum Chit Chat & Service StoriesReplies: 16Last Post: 10-09-2008, 10:06 PM -
Questions about Chiller Design
By Vincent Yu in forum FundamentalsReplies: 9Last Post: 06-06-2008, 01:00 PM -
air conditioning questions and answers
By sid in forum Tools and CalculatorsReplies: 7Last Post: 20-08-2007, 01:06 AM -
questions
By parry in forum Chit Chat & Service StoriesReplies: 17Last Post: 31-10-2005, 08:46 AM
