Thread: fujitsu asy faulty
10-08-2008, 06:32 PM #1
fujitsu asy faulty
HI i have installed a second hand fujitsu asy12usccw split unit. if i press the remote start button the red light flashes twice then the unit shuts down. The unit has been gased with 410, if i hold down the manual / auto button on the pcb the unit works after 10 seconds if i keep my finger on it it will blow cold air for approx 11 mins, then shuts off. I think one of the 2 pcbs is at fault but not sure, if i need a new pcb can anyone help find one cheers.
P.S need it working quick as i live in Menorca Spain and it is bloody hot in August.
10-08-2008, 08:31 PM #2
Re: fujitsu asy faulty
Is the red light the only one lit up?
2 Flashes of the Red LED would mean a sensor problem but this would also pulsate the Green LED...
10-08-2008, 10:06 PM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
That is thermistor error. Could be room air temperature or heat exchanger thermistor. Disconnect unit from power suply for 5 min. and reconnect. When operation LED start to flashes 2 times, pres TEST button on the back of remote and watch Timer LED. If flashes 2 times, it is room sensor, and if flashes 3 times, it is heat exchanger sensor.
That doesn't mean that sensor is faulty. That mean only that value read from sensor circuit is out of set borders.
Recover refrigerant and charge new fresh refrigerant by weight, and then check again performance and for errors.Last edited by nike123; 10-08-2008 at 10:15 PM.
11-08-2008, 02:45 PM #4
The green light does not light up at all the red lights pulses twice then the unit shuts down i have unpluged the unit for 30 mins and when i try to switch on the same thing happens.
12-08-2008, 01:26 PM #5
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
14-08-2008, 11:19 AM #6
voltage checks out ok does anyone know where you can by new boards
your opinons on fujitsu please
By acgibo in forum Air ConditioningReplies: 18Last Post: 26-08-2009, 05:06 PM -
Faulty Fujitsu invertor wall split
By nick_nst@aapt.n in forum Trouble ShootingReplies: 7Last Post: 30-06-2008, 08:04 PM -
Fujitsu or not?
By LRAC in forum Air ConditioningReplies: 14Last Post: 29-08-2007, 09:45 AM -
desperately seeking fujitsu
By rbartlett in forum Air ConditioningReplies: 7Last Post: 04-08-2007, 09:06 PM -
Fujitsu Cassette not running
By Climateman in forum Air ConditioningReplies: 20Last Post: 22-06-2007, 10:39 PM
