    Andy noblet's Avatar
    Andy noblet Guest
    Unhappy valve plate failure
    taken over system with 2 semiherm units working freezer @-25 c one system works perfect, other system discharge valve fails or in the past compressor has broken a piston .
    system on r404a tev s/heat 5c suction press 35psig disc press 190 any suggestions
    Jun 2004
    wales
    Re: valve plate failure
    you say it has two units but does it have one or two evaps?
    Sep 2003
    ISRAEL
    72
    4,248
    superheat too high for a freezer, should be maximum 3C
    at 5C superheat you are most likely to get liquid in your suction line,.
    chemi
    Aug 2001
    1,046
    Is there any way that refrigerant can condense nearby in the discharge line or in the valve assembly, say on the off cycle, or syphon back when the unit is off? If this happens when the head is cold, a tiny amount of liquid can cauase a trnendous amout of damage.
    This may happen if your unit is working as a lag system. Because the lead unit works most of the time, the conditions for liquid settlement don't exist.
    It's not unknown in the UK. I have found it in the past where hydraulic damage is caused in the top end of the piston assembly and in the muffler that may be right in front of it.
    If you have air cooled condensers sitting above the unit, have a look for check valves to prevent liquid settling at the lowest point by gravity.
    ________
    C77
    Oct 2001
    Nottingham UK
    5,668
    How is that Chemi?
    Any superheat above boiling point surely means that the liquid is now certainly a vapour? am I missing something?
    Sep 2003
    ISRAEL
    72
    4,248
    of course you right argus.
    NRV after discharge valve will protect it from liquid migrating back.
    also good design of discharge piping can do wonders.
    chemi
    Sep 2003
    ISRAEL
    72
    4,248
    hi frank,
    I was talking about a freezer. in AC its fine.
    chemi
  1. Diagnosing valve plate problems
    By Dan in forum The Trail of Tears
    Last Post: 16-10-2009, 10:37 AM
  2. Close call (eye opener)
    By Tycho in forum Industrial
    Last Post: 17-03-2006, 07:33 PM
  3. Need a correctly sized valve
    By Abe in forum Commercial
    Last Post: 26-10-2005, 08:42 PM
  4. Replies: 5
    Last Post: 16-10-2002, 12:38 AM
  5. Valve "Hunting"
    By Abe in forum Trouble Shooting
    Last Post: 21-01-2002, 12:29 AM
