Results 1 to 2 of 2
Thread: Scroll comp
09-08-2008, 05:38 PM #1
Scroll comp
As a Scroll comp has no valves, how do you carry out a pump test
the unit im looking at is a IMI MCU 100+ Condenser
thanks Dave
09-08-2008, 06:47 PM #2
Re: Scroll comp
Dave,
To test if a scroll compressor is pumping properly, the compressors current draw must be compared to the manufacturers compressor performance curves using the operating pressures and voltage of the system.
Closing the suction valve to determine how low the compressor will pull suction pressure could damage a scroll.
Here is a link to Copeland's AE bulletins. Check out the Section 4 list of scroll bulletins. You might start with 4-1312.
Digital scroll
By archibaldtuttle in forum CommercialReplies: 3Last Post: 06-01-2010, 05:27 PM -
scroll comp speed
By O_E in forum ElectricalReplies: 6Last Post: 27-06-2008, 02:47 PM -
comp oil
By headgasket in forum Technical DiscussionsReplies: 2Last Post: 14-10-2007, 07:34 PM -
help me economizer for scroll comp
By tranquanghvac in forum FundamentalsReplies: 14Last Post: 30-11-2006, 08:51 AM -
copeland zr scroll
By stevo in forum CommercialReplies: 10Last Post: 22-07-2006, 08:13 AM
